You could make one out of flat aluminum sheet rolled up and riveted together, Then block off the area not exposed to the shroud with more flat aluminum plate. You want about the last third of the blade tip exposed at the end of the shorod to get the depth correct. You must also account for motor movement as even a stock motor will wallow around on sponge rubber motor mounts by a half inch or more.
Without a shroud the air flies off the ends of the blade cutting it's useful diameter by two thirds. This much loss in air flow usually leads to over heating.
