Thanks Dave. Did your manifolds come with an “ear” for the alternator to be positioned on the driver side like they did in ‘64?
I’ve seen a few other sets that have a different looking provisions for the alternator like the ones Pete posted above.
I’m going to look at my mine today to see what my drivers side manifold looks like.
Ps what have you guys ran as exhaust X or H pipe?
The manifold I used was for the '63. It requires the complementary alternator mounting brackets. The '64 manifold are just like dcairns shows and use different alternator brackets. Either manifold will fit on either car but the alternator brackets need to go with them.
dcairns bought the 'clean' passenger side manifold (no difference between 63 and 64). I saved about $100 (as I remember) 'making' my own 'clean' manifold from a driver's side.
Function and fit, either works equally as well. It was surprising easier than I thought it would be. Mine did NOT look as nice as dzauto's but I was VERY happy with the results.
If you are happy with the way your alternator mounts now, you likely can use your existing mounts if you replicate the existing manifold casting (except for the diameter).
As for X or H? I was not at all interested. I did NOT want anything hanging down any lower (reduced ground clearance). Because the entire system requires fitting BELOW the frame, the entire system would have to be custom. That's simply a conclusion. Because I did not use them I can't state claim that as fact.
Here's a pic of the exhaust system as it 'fits' within the x frame. It's not my car, but my car looks like that (except for the glass packs in the pic; I've got the mufflers that came with the system I bought) from that view. The assembly manual drawings show this configuration.
Also attached is a side view of my car. I'm (on purpose) 'up' about 3" in the back; I used the station wagon springs specifically for that purpose. Just a 'visual' for info.
