ok guys i can use some help on this one. i have a 2005 impala that showed up with a gas line rusted and about to start a leak. i can get some gas pressure hose and gas hose and some 3/8 and 5/16 line and just do that repair, but i found this kit on ebay and i would like to know if anyone here happens to know if this it the complete repair kit? the sellers can't help but maybe some here have used these.
Fuel Line Set For 2000-2005 Chevy Impala 3.8L V6 2001 2003 2002 2004 B779TW | eBay
so can you take a peek and tell me if this looks like the repair kit from the filter to the rail and from the rail back to the tank.
on the gm arts site it looks like the tank has that nylon type line from the pump down to about where the filter is for both the pressure and return lines. here if that site and item 16 and 17
Fuel System Components for 2005 Chevrolet Impala | GM Parts Online
thanks for any help and ideas. this repair is for a vet that i met on a local forum and is disabled and i have been helping him with some of his car repairs. thanks bp
Hi Bob. I think you will find the help you need at impalaforums.com. This forum is for the older rear wheel drive Impalas. It doesn't cover the front wheel drive Impalas. Good luck with your question there, I'm sure someone will help you!
ok thanks i did post on that site but there must not be anyone there as everytime i post i never get any answers. i will try again in a different section. it may get moved but then i know someone is alive over there. anyway you never know on this site someone may just have one of the 05 impalas and can help out. thanks darth
bp.
