I've developed a coolant leak externally from intake gasket..I haven't pulled it apart yet but wondering if it has block off plates to prevent heat under carb, would it get too hot if I removed the plates? I was having trouble getting divorce choke to work and I think its maybe because the passage is blocked, but I don't want to put heat under carb if it may be a problem
1961 Impala 2 Door Sedan
I can't answer your later questions but I can provide the following - I was having coolant leaks pooling up on the IM and where the IM meets the heads and the gasket looked wet. I assumed it was leaking from the thermostat housing. I did a cooling system overhaul this spring with new water pump and new thermostat/housing. The leak continued. Decided I'd go ahead and pull the IM bolts one at a time and put sealant on the threads (since I never did when installing it, didn't know any better). Almost every bolt was a little loose, 1/2 to a full turn to get back up to torque spec. Sealed the threads, torqued each one as I put them back in and not a drop leaking from my cooling system now.
I checked the torque of bolts and were ok. I pulled one bolt and sealed it but I think it would have caused a oil leak if it came up from the bolt. I can see a small split at the gasket and I believe I have a gasket failure. Thanks for you info, I appreciate it. PS I think the tightening of your bolts took care of your problem. Glad yours was that easy.
'... would it get too hot if I removed the plates?': No. The heat from the exhaust (via the heat riser valve) doe not impact coolant temps. It may take a little longer 'warm up'.
Here's some general info:
Does not divorced choke on a QJet require the heat from the exhaust to function? I believe so. The choke problem may (emphasis on 'may') be related to a heat riser valve problem.
Just info.
Just info.
Thanks Pete for the info.
But wondering if block off plates removed would it be too hot for the the gas in the carburetor? If not it should allow my divorce choke to work correctly
If you can't decide... there is a middle ground ;D Some intake manifold gasket makers supply plates that partially block the passage. They have a circular hole about 1/2 inch in diameter in the plate.
I opted for that choice in my motor. Can't say if it is any better or worse, but icing it not much of a problem in Southern California (warm and usually dry air).
Discussion Starter · #8 ·
Thanks, that is a great idea
