Anyone have decent instructions on how to take apart the tilt parts so that I can paint the covers around everything?
These are a PITA. Right up front I would recommend painting it assembled.
It is not all that obvious how it comes apart.
I found one video on YouTube but it starts well but one can see he quickly gets frustrated and fails to tape the assembly. I am confident he had many tries before getting it together.
The first picture has the top outer housing. GM has a tool for this also as it is held on with only a interference fit.
I go mine off using a puller and reversing the jaws. Really easy to F this housing up using too much force or the wrong tools.
You will need a puller to pull the bell shaped housing from the shift tube. GM makes a special tool for this "shown"/
I'm going to end with my first statement. If it's not broken paint it as is, you can thank me later.
Lip Automotive lighting Eyewear Audio equipment Headgear
Product Automotive tire Gas Cylinder Electric blue
Automotive tire Gas Auto part Serveware Automotive wheel system
Yah the problem with painting it without taking it apart is the seam where the turn signal cover and the mast jacket cover meets gets cracked and looks terrible. What tool is used to take off the column shift cover/mast jacket cover?
The one in the picture is KENT MOORE J-22549-2 Steering Column Shift Tube Installer
Kent Moore Specialty Service Tool Steering Column Shift Tube Remover J-22551 was used to take it apart.
they are both available on eBay for roughly $30 each.
I am slowly getting there. How the hell do you use these Kent Moore tools? It looks like this locking plate and shaft tube need to come out in order to get the cover off?I googled around and haven't really seen much on how to use the tools.
Watch Automotive tire Wood Rim Door
