1 - 2 of 2 Posts
Hi, any specific specs out there for an axle upgrade without pulling them out? Stock axles still equipped in my original 327/300 4-spd SC. Thank you
30009
67 Caprice
Yukon and Dutchman make replacement axle shafts for 58-64 Impala, but they aren’t cheap and if you stick with the stock carrier they’re still going to be 17 spline when you turn out the shop lights.
The originals have lasted this long with stock HP so if you’re staying there, either brand should be fine and better than stock because they’re 1541 steel instead of 1039 and, well, they’re new.
I’m lost on the “without pulling them out”, unless you’re referring to the entire rear end assembly, and not the separate axle shafts.
1 - 2 of 2 Posts
