in September of 66, Chevrolet published Engineering Service Letter CEC Ref. ECR 81781 to correct an Akermann issue on police cars. While I'm still trying to get a full copy of the service letter, I have summarized a 5 page thread from another forum into the following two solutions:
Solution 1 ("90%"):
67 Center link
67 Idler Arm
Idler Arm Spacer
Template from the service bulletin (locates the 67 idler arm to work with 65-66 pitman arm.
Solution 2:
67 Center link
67 Idler Arm
Idler Arm Spacer
67 Pitman Arm
No template. Relocate Idler Arm mount off of crossmember.
Holley is making suspension parts in the USA under their Proforged brand. They have a very high quality idler arm for about $50.
Part Number:
102-10069
Holley doesn't have a center link yet. Not sure of the quality, but I sourced mine from Classic Industries.
Part Number:
DS756
I chose to go with option #2, so I sourced a 67 pitman arm on eBay.
GM Part Number:
3900559 A
There may be other part numbers for the 67-70 pitman arm, but I know this one to be good.
Made the spacer today. Had to make a transfer punch. Used 7/16 drill stock turned down to match the idler arm mount holes. A quick heat tread and oil bath, and viola, center punch ready for duty.
The spacer is made from cold roll, with 3/8-16 tap drill (O) holes, but didn't tap the holes yet. Instead, I made a pair of locater pins so the idler arm and spacer can be located and clamped to the frame for welding. The plan is to weld the spacer to the frame, then drill through the frame, and tap the holes at that point.
The car and new frame are going to the body shop soon. The spacer will be located and welded with the frame mounted and leveled on the frame rack. Will post more pictures soon.
Spacer:
Locater pins:
Spacer and idler arm bracket with locater pins:
How it will eventually look. (From another forum):
Solution 1 ("90%"):
67 Center link
67 Idler Arm
Idler Arm Spacer
Solution 2:
67 Center link
67 Idler Arm
Idler Arm Spacer
67 Pitman Arm
Part Number:
102-10069
Part Number:
DS756
GM Part Number:
3900559 A
Spacer:
Locater pins:
