Doing some reading and looking to update my steering box on my 66 impala.
What I read was that one could use a 1995 Jeep grand Cherokee steering box as noted below.
from impalatom
When using the Jeep GC steering box you will need a new rag joint. I believe the right one came from an 80's Chevy PU. In my case I bought the correct rag joint from Lee Steering but I later found out you can purchase much cheaper from Autozone or similar. I am fairly sure the Lares #200 is the correct rag joint. IF your car has original power steering you will use the original pitman arm. You do not use the Jeep GC pitman arm. Note, if your car was not original power steering that pitman arm is different and will not work. You would need to find a 65 PS pitman arm.
Also you will need to either use the Lee Steering o-ring to flare tube fitting inserts or you can buy the adapter fittings. The fittings can be sourced from several places such as Classic Performance Products, the part number for the set is 605SOL. I went with the Lee inserts to keep the appearance stock, there was absolutely no problems with the threads tightening up into the metric threads of the Jeep GC steering box. If you are worried about this you can always use the adapter fittings I referenced above.
The nice thing about using the Jeep GC box is the 2.9 turns approx. lock to lock compared to original approx 4 turns lock to lock. Also the Jeep GC box gives the full 87.5 degree sweep same as original with a much firmer feel. I do not believe any early 70's steering box is the quick ratio steering.
I priced it all together for about $180 total.. used box $100, adapters, $60 + shipping from eBay..
Or one could go the Lars 974 route: found on rock auto.
LARES 974 Remanufactured; Includes New Steering Coupling Assembly
w/ Power Steering; Fast 10:1 Ratio; (3 Bolt Mounting Holes) Uses Camaro IROC Internals; Correct OE Turning Radius
comes with coupler and doesn't need hose adapters..
$412+ 25 shipping total unless they will take your old box as a core... which I'm not sure they will..
For the money I'll probably go the jeep and ebay route.
I'll keep you posted!
from impalatom
$287.79 | $125.00 core | $412.79 |
