1 - 2 of 2 Posts
I've seen the posts on this subject, but I had a particular question. So I'm doing the column to floor shift conversion and already have the factory style console and floor shifter mounted with the NSS. Have not hooked up the wiring or linkage yet.
I picked up on the console and shifter and luckily it had the console harness, but also had the connection and had been cut. So im wondering if i connect the column harness to the connector that was cut and plug to the console harness will it operate as it should? Thanks in advance.
Discussion Starter · #2 ·
Thumb Office supplies Nail Cable Electrical wiring
Here's the harness connector so ones end has the connections to the console and the other end has the the the neutral safety switch wires and other wires i can splice into the main harness to give power for the console lights. Electrical is not my thing so i wanna be sure it will work fine.
Finger Thumb Wrist Nail Electrical wiring
1 - 2 of 2 Posts
