I did read somewhere that these old impalas do have an eccentric adjusting bolt on the lower control arm.
Sorry I should've mentioned but I was in a bit of a rush posting. I should also have mentioned you need to do it on as flat a surface as you can, trying to mimic a wheel alignment machine.
I did research on McGaughys vs CPP drop spindles back in 2011 & went with CPP because I read so many forum threads regarding issues with McGaughys (here's an example of a tri five owned with other users chiming in -
Anyone install McGaughys drop spindles? - Chevy Message Forum - Restoration and Repair Help ), but I also discovered that CPP have their own issues too. Firstly you have to get, from memory, 1/8" machined off the drop spindles which added considerable expense to a part I thought was a straight bolt on. And, when fitted the tie rod becomes closer to the ground than the rim (15" rims) which is a legality issue where I am as it would contact the ground first in the even of a puncture & cause steering issues. It also can become a clearance problem mounting even quite low curbs if you approach them at the wrong angle.
I don't think you'll have a problem finding someone that can do the job, they're not that complicated, but the issue I faced was finding someone with a big enough wheel alignment machine for the car, but probably not an issue you'll face in the U.S.
If you look into Global West upper & lower control arms you'll read that they've changed the geometry from factory specs which they say reduces the inherent factory "bump steer". Now i'm certainly no expert but I think there's a very good possibility that by dropping the front 2", without any other complimentary changes, that you may well be making that bump steer a lot worse than factory.
Personally back in 2011 I wanted to refresh & improve the whole suspension as it was 44 years old at that point & I didn't like the look of all that pressed sheet metal & rubber bushes, and our country roads are pretty poor. I preferred the hotchkis square section rear lower trailing arms rather than the Global west's round section trailing arms(
1967-1970 Chevrolet B-Body Rear Suspension Package w/ Dual Upper Arms) so I went with Hotchkis on the rear, unfortunately Hotchkis don't offer any front end parts for a 67 so I went with Global West upper & lower front control arms and their front strut rods as well.
The car is very nice to drive & all those suspension squeeks & creeks are long gone. My only complaint is with the Global West powder coating, it's not aging well at all particularly on the front lower control arms & if I had to guess I would say it's a result of poor pre coating preparation of the steel. I'm just not a fan of powder coated anything now, it just seems cheap & nasty, especially when you take into account how long old fashioned paint can last. I guess it's just a sign of how far quality control has fallen now that nothing is made to last anymore.
