All Forged 383 Short Block
Everything is new. Located in Frederick County, Maryland. Cash only & sorry but I will not ship so if you're interested you'll have to pick it up.
My 66 is a factory big block car and I don't plan on changing that so the short block needs to go.
Engine Block: Select GM High Nickel 010 Casting 4-Bolt Main With ARP Main Studs
Thermo-cleaned / Pressure Tested / MagnaFluxed
Mains Align Honed w/Studs Installed
Deck Surface Milled/Equalized Using Squaring Fixture
Cylinders Bored / Torque Plate Finish Honed 90 Deg. Off Mains To 4.030"
Clearanced For Rod/Stroke Combination
Fitted With New Cam Bearings, Freeze/Galley Plugs
Rotating Assembly: Eagle Throttle Response Competition Series
Internally balanced to race specs on a CWT Multi-Bal 5000
Crankshaft: Eagle ESP 4340 Light Weight Non-Twist Forging
Multi Stage Heat Treated, Stress Relieved, Shot Peened
Nitrided, Magnafluxed, Sonic Tested, and Micro-Polished.
Lightening Holes In All Rod Throws
1.889" NASCAR/Honda Rod Journals For Reduced Drag/Weight
Connecting Rods: Eagle ESP 4340 Forged 6 Inch H-Beam
7/16" ARP Cap Screw Bolts
Weight Matched/Light Weight
1.889" NASCAR/Honda Rod Journal Size For Reduced Drag/Weight
Pistons: MAHLE -5cc Forged/Coated Race Pistons
Light Weight Slipper Skirt Design
Fully Machined Crowns
Grafal Anti-Friction Coating On Skirts
Phosphate Coated To Reduce Micro Welding and Pin Galling
Pin Bores Finished On CNC Boring Equipment
Hand De-burred
High Strength, Light Weight, Steel Pins
Race Proven Round Wire Locks
Piston Rings: MAHLE Plasma Moly Low Drag
Low Drag For Increased Power/Reduced Friction
Ultra Flat Ring Flanks For Maximized Ring To Piston Seal
1.5mm / 1.5mm / 3.0mm Ring Pack
Bearings: Clevite H-Series Race Main Bearings
Federal Mogul Competition Series Rod Bearings
Camshaft: Competition Cams Custom Ground Mechanical Flat Tappet
Pro Plasma Nitrided For Durability
Custom Ground High Intensity Profile
4-7 Firing Order Swap
Timing Set: SA Gear Billet Double Roller Timing Chain w/Torrington Bearing
Comp Cams Lock Plate Kit & Thrust Button
(Thrust button used on all high rpm applications regardless of cam type)
Engine Works Heavy Duty Steel Timing Cover w/Thrust Surface
ARP Timing Cover Stud Kit
Victor Reinz Crank Seal & Cover Gasket
Oil Pump: Schumann Pro Series Race Pump
Precision machined, high strength, iron alloy casting
Full flow driven shaft oiling
Anti-cavitation relief grooved cover plate
Anti-aeration bleed off oil supply
Exact mesh gear set
Oil Pump Stud: ARP 230-7003
Pump Seal: Schumann Copper Pump To Main Seal
Pump Shaft: Moroso 1 Piece High Grade Steel
Pump Pick-Up: Canton Racing Products
Oil Pan: Canton Racing Products Drag Race Pan
Competition Oil Recovery System With Windage Tray and Crank Scraper
Trap Door Baffle
Magnetic Drain Plug
6qts Plus Filter
Pan Gasket: Fel Pro 1 Piece Rubber With Steel Core
Rear Main Seal: Fel Pro Race
Asking Price: Best Offer
Condition: Excellent
City: Frederick
State: Maryland
Hand De-burred
Exact mesh gear set
Trap Door Baffle
Magnetic Drain Plug
6qts Plus Filter
City: Frederick
State: Maryland
