1 - 20 of 23 Posts
Lifetime Premium Member
Hi Everyone,
(My apologies in advance for the long windedness of this post!)
I want to upgrade the brakes on my Impala to front disc, and have been doing the research on what products are out there.
Firstly: 1969 Impala 327, stock with stock ride height, currently with power drums. It’s a street driven car.
My main criteria is: stock appearing, and direct bolt on. I’d also like to use a single source – mainly given comments I found throughout the forum suggesting a single supplier to avoid problems. Not to mention that sourcing several parts in Canada can sometimes be difficult. Some of the kits I found will fit a 1969 – but they are actually designed for 1968 and you need to source 1968 spindles – not something I’m overly interested in doing.
I’m looking for feedback on the various suppliers and kits they sell; how easy were the kits to bolt on, what kind of quality are the kits, etc
Also curious if anyone went the drilled/slotted route, and was it worthwhile (if you have the ability to compare)?
Here’s what I’ve found:
MP Brakes
Has a kit, $995 with standard rotors, $1120 with drilled/slotted. Only concerns about the booster not appearing like stock.
Direct Fit Brakes Inc.
Has a kit that supposedly does 1969, $549 for standard, +$40 for drilled/slotted. One of the cheapest kits out there. In this case, my experience says you get what you pay for, cheap kit = cheap/low quality parts – is this the case here? Thier booster appears more stocklike in the photo, hard to tell though.
The Right Stuff Detailing
From what I can see, these guys have an amazing set of conversion products, but not for a 1969.
Stainless Steel Brakes
Like above, I’m seeing great feedback throughout the forum – but seemingly nothing available for a 1969. (Year One sells SSBC, says “use 1969 spindles”)
Performance Suspension Technology
I only found one response for PST on the ‘velle forums; they seemed happy, but nothing for 1969.
Classic Performance Parts
I didn't see anything about this paticular vendor.
Musclerodz
Seemingly nothing beyond a 1964 Hydratech kit.
Impala Brake Parts
I found one kit, $1150, stock ride, dual piston calipers. Listed for 1958-1970. Looks like a bottom only kit. There’s a few others, like a 14” wheel kit for $850, non-stock appearing booster, but I have 15” rims, so I’d rather find a kit with larger rotors for better stopping (I’ve driven cars with undersized rotors…), not to mention something with a stock appearing booster.
Impala Bobs
These guys have two kits. One is designed for 1968, you need 1968 spindles, $799. The other says “Your Spindles”, $1099. I haven’t seen any feedback in any of the forums on either of these kits.
Baer, WilWood, Kore3, and Global West all carry performance style brakes – probably great on a kit/custom car, but not something I’d want for a stock appearing Impala. :)
Classic Industries
Surprisingly, I couldn’t find a 1969 kit. Perhaps I’m blind - it was probably right there staring back at me.
Have I missed any vendors?
Thanks in advance
-Rob
Looks like you've done some homework!
As far as drilled/slotted rotors go; they are more for looks on street cars and actually diminish the swept surface area of the rotor. Rotors like these are designed to dissipate heat more quickly to reduce fade in a racing situation, but under normal driving conditions with a big 'ol Impala they won't make a difference. You need lots of surface area with a big car.
From what I have gathered the 69-70 models front spindles were unique. Most companies that sell conversions for that year have specific instructions about the spindle. I'm sure some other members here can offer more help for the 69-70 model.
Yep, for the 69-70 (I have 70) you need spindles from 65-68. I got set of used ones on Ebay. I do not think changing spindles will change the stock appearance much more than look of discs where the drums were.
I have manual drum brakes all around and conversion is on my to do list. I just need funds to get the kit. The ones I was looking at was CPP and Matt's Classic Bowties. Both sets are put together by CPP but for some reason MCB is selling them about $25-50 cheaper. Look on Ebay where power front set for our cars is $425 plus $55 shipping from Matt's.
I can't comment on quality though because I haven't installed them yet. The only thing I know that CPP and Matt's kit is basically disc kit for 79 Malibu. My only concern is that the rotor is I believe either 10.5" or 11" which may be kinda small especially for my 2 ton wagon.
Anyway, let us know once you decide and post some pictures of the conversion. I would be curious how smooth it went as I am probably another 2-3 months before I can order the conversion kit.
It will be a while before I actually do the install - the cars about to go into storage for the season.
I'm doing my research now so I know what I'll try & pick up later this year as the dollar approaches parity.
One advantage I found going with 68 spindles is apparently cars ordered with disc brakes on 67-68 had dual piston calipers, whereas the 69-70 counterparts had single piston calipers.
That to me would be a good reason for changing the spindles. Right now though, sourcing a set of spindles means I'd probably have to import them - these cars aren't numerous in our scrap yards around here, unfortunately!
Regarding the slotted/drilled feedback, that settles my thoughts - I will go with the regular rotors, makes sense.
Thanks!
Thanks!
1965-'68 Impala's used the four piston fixed bridge Girling Style disc brakes that were used on the C2 corvette. The 1969-'70 single piston disc brake is unique to itself and shared by nothing else (which is the reason they got rid of it, since it goes against GM's policy of one part fitting as many cars as possible). So if you have drum brakes on a 1969-'70 Impala you have to swap out the spindles and retro fit the earlier disc brakes which are still easily found in many parts houses.
The old style brakes have one fatal flaw. They will corrode baddly (cast iron caliper with aluminum pistons in the presense of water makes for corrossion thanks to alkalyn brake fluid. SSBC got their start in the high performance brake business by sleeving the cast iron calipers with stainless steel sleeves (which is why they are called the Stainless Steel Brake Company). If you do get the earlier disc brakes be sure to have SSBC upgrade your cast iron calipers to SS liners.
Neat background on Stainless Steel Brakes! I didn't come across that previously.
I suppose this is something I should be asking the other vendors about, what metals are used in the pision/caliper assembly - or do you think these kits would contain the corrections needed (eg all cast iron instead of a Al/Fe combination?)
-Rob
Hey Rob,
Nice bit of research. Here's what I did to put discs on one of my 70's. Picked up complete system from a70 (spindles,calipers,discs distribution/proportioning block, and booster,from Classic Chevy Enterprises, in New London,Wi. The guys name is Randy Popke. Too bad Lake Michigan is between you and him. Maybe you guys could meet in Sault Ste.Marie!!!:) Sent the booster to "Booster Dewey" in Oregon to get rebuilt and plated.This is where MOST of suppliers get theirs from. Then www.oldmusclecars.com supplied rebuild kits for calipers WITH SS pistons as BIG D mentioned. New bearings and seals I got locally,just make sure to take old ones with you. Now this next point has been brought up before, and I have CRS (Can't remember Sh-t) and not sure where I saw this....BUT new discs are the same as ones used on a Corvette. Which year??? This is where CRS kicks in. Now as for brake lines,got mine from Right Stuff Detailing. I know this sounds like a lot of work and $$$ , but IT ALL fit and I can go to Auto parts store and just say 70 w/disc brakes, without having to remember what year,or special bearing to fit drum spindle to Rotor. Hope this helps...it wasn't as much $$ as one would think.
Gary
Check Out ABS Power Break, Inc.
www.abspowerbrake.com
They may have what you are looking for. I also have a 69 Custom and they looked like they had complete sets.
Ape Out.
That's right I've seen this on the internet but I believe the link isn't good anymore. Using 1980 covette(used for a multiple number of years) front rotors(fallout style) on the original 70' hub(you'll have to seperate the hub from the rotor, yes it is acutally two pieces) you then can place the corvette rotor on the Imps hub and viola!
Also as a point of info all 70' custom coupes had front discs as standard equipment.
Discussion Starter · #11 ·
I also found Late Great Chevy appears to sell a direct bolt-on kit that has the same photo as MPBrakes, for the same price as MP Brakes ($995 for non-slotted)
I didn't see any pricing on ABS Power Brake, but it appears as if they sell the Delco factory style booster/master combos... I'll email to find out.
BBDropTop - thanks for the detailed info on building a kit up - I like the idea of being able to walk into a parts shop and buy replacement parts... Again, the kit idea appealed to me in Canada as it's one big shipment rather multiple smaller shipments, but I think given the selection/feedback, I will consider your suggestions and price that route out as well.
Thanks guys, keep the ideas & suggestions coming!
As far as the 4 piston fixed calipers go: they were offered on the Corvette starting in 1965 but weren't offered on other GM cars until 1967 and only ran until 1968.
I don't think you'd want to go this route. The calipers for B bodies are unique and very hard to find. Calipers from the other models will NOT work (there are subtle differences like the width and brake line location). And these will cost you @ $140-200 each and will have a core charge of $125 for each old caliper. I have these on my Caprice and learned a lot about them when I had to have them rebuilt. Most shops that have them won't even sell you a pair unless you have good cores to trade.
I think your best bet is to find a way to install a more popular single piston, floating caliper disc brake set up from 1971+. That way in the future you can find the replacement parts easily and affordably. (I did this on my 67 Camaro and it was cake.) Or find an original 69-70 disc set up at a swap or eBay and restore it.
Discussion Starter · #13 ·
Do you have any contact info, eg an email address or phone number for Randy? I checked out the website, but the "About Us" page is blank (sorta like they're transistioning websites or something)
thanks!
Hey Rob,
Randy is usually traveling the country picking/delivering parts. He is at most major swap meets,and goes south and west to find quality used parts. THE best way to get him is by phone 920.982.5871. You will probably get an answering machine which he usually checks...daily(sometimes). If you're ever in the Green Bay area,he sees customers by appointment. Then you drive around, he has three farms with CARS. Most are in barns or chicken coops, and not small ones either. I recall walking thru three of the coops probably about 100 feet long filled with nothing but B-bodies. And he is always open for trading parts.
Gary
Discussion Starter · #18 ·
Spoke with Randy, he has nothing available disc wise, right now. He'll keep his eyes out for me.
Discussion Starter · #19 ·
Hi Guys,
Still doing research. I will post my findings shortly, but basically I'm considering putting together a kit which would use a new master cylinder, but with my OEM drum booster (which works fine).
Reason I'm thinking of going this route is to keep the OEM look; buy basically a manual disc kit as it contains everything BUT the booster.
Has anyone tried this? Are they technically the same booster pn#?
Thanks.
Any Updates?
Ape Out.
1 - 20 of 23 Posts
