1 - 1 of 1 Posts
Vendor
The braking system in your Chevy Impala is an elaborate mechanism, where every component should be in an impeccable state so that the system could function properly. When it comes to brake maintenance, most drivers take care of pads, rotors, and calipers, while the lines and hoses are left overlooked. Although they are the ones that rust from exposure to moisture and corrosive road treatments and fail at the most unexpected moment. Pre-flared and cut-to-length lines with fittings can save time by eliminating the whole replacement process and this is where Fine Lines has got you covered.
This brand offers correct-as-original reproduction parts including brake and fuel lines, brake, fuel delivery, transmission system parts, and hardware. They feature correct end forms, offer OEM fit for trouble-free installation, and can be manufactured from the original material or stainless steel. Manufactured from industry-leading materials using up-to-date equipment, they provide everlasting reliability and enduring value. With Fine Lines Products, you can avoid costly repairs and make sure that your braking system is in great condition!
Fine Lines™ | Automotive Brake, Fuel, Oil, Power Steering Lines — CARiD.com
1 - 1 of 1 Posts
