GM used an Eaton Posi. Springs clutches and steels are available at Randy's Ring and Pinion (https://www.randysworldwide.com/), or from your local mail order parts store:
EATON 29590-00S Eaton Preload System Service Kits | Summit Racing
Find EATON 29590-00S Eaton Preload System Service Kits and get Free Shipping on Orders Over $99 at Summit Racing! Eaton preload system service kits have been designed to set up your aftermarket differential correctly. They include necessary spacers and hardware to adjust the preload on your...www.summitracing.com
Thanks for the fast reply. Checked with EatonGM used an Eaton Posi. Springs clutches and steels are available at Randy's Ring and Pinion (https://www.randysworldwide.com/), or from your local mail order parts store:
Thanks Big Dave for the fast reply. I contacted Eaton andGM used an Eaton Posi. Springs clutches and steels are available at Randy's Ring and Pinion (https://www.randysworldwide.com/), or from your local mail order parts store:
Thanks for the fast reply. I contacted Eaton and Randy’s Worldwide and both said these springs were obsolete, and the only option is search on a forum or maybe locate some at a flee market. I’ll keep searching.GM used an Eaton Posi. Springs clutches and steels are available at Randy's Ring and Pinion (https://www.randysworldwide.com/), or from your local mail order parts store:
I also ordered some from Summit and they were way to short, so I returned them.Thanks for the fast reply. Checked with Eaton
Thanks , Do you know how I can contact Tom?Try to contact Tom Parsons in Texas. I believe he is more '55 to '64, but he may have some newer parts.
Thanks, for the info.I'll send you a PM.
Need (4)) 200# or 400# springs used in a 8.2 posi differential. Differential from a 1966 Chevy Impala, 283 ci. 4 speed. Approximately 2 1/4” long by 5/8 wide. View attachment 29521
Not sure how many years this unit was in use or what vehicles used it, maybe someone one the forum can help. My situation was 2 of the springs were removed and wanted 4 new ones to get it back the way it should be. I think one of the previous owners removed 2 springs because it chattered while turning, most likely there was no limited slip additive added to the gear oil.Hi I also have a 66; but a chevelle that came with a 327, PG, 308 posi from DANA. So this post has my interest. My Posi doesn’t work properly. I was able to run down a new NOS clutch pack. No luck on springs to date or someone to rebuild the posi. It’s still in the car.
I was wondering what years this unit was used if you know and or what cars may have a unit installed? Also how do you know if springs are bad? Thanks
