Pads come in a huge variety of friction compounds. Which ones did you get?
I replaced all 4 calipers and also did the braided lines, the rear calipers that came with the car are the ones that come with the E- brake , my car has no E-brakePossibly air in the system, easiest test is to pump the brakes several times before applying them, if the car stops better it's likely air in the system.
it could also be as simple as one caliper not operating as well as the rest, and that could be a problem with the caliper itself or an issue with the brake line to the caliper. If the lines are still the old rubber type replace them with braded brake lines, that alone makes a big difference.
To do a basic caliper test, get the car off the ground with someone in the car, have them apply the brakes with a minimum amount of pressure, while you rotate the wheels to try & determine if all the wheels have the same resistance to rotation as each other.
Thanks I will try out that toolOne other thing I just noticed. With that style proportioning valve, you're supposed to use this tool to keep the valve centered when bleeding the brakes. If that tool isn't used the valve can then be off center, which will then restrict brake fluid pressure to either the rear or front brakes until it's re-centered, but not both.
Bleed the brakesPurchased my 62 lmpala less than a year and it already came with disc brakes front and rear , I noticed that I have to apply firm pressure in order for car to stop, I replaced all the brake pads and bled the brakes but still the same . My pedal does not go all the way down . Goes about half way my only problem is the brakes don’t grab and I have to apply the brakes kind of hard , I don’t know what brand kit this is, any input? View attachment 32041
How much manifold vacuum do you have. My aftermarket disc brakes need a minimum of 14 -15 in. I only make 12-13 in. Which gave me a hard pedal needing a lot of force. I ended up installing a vacuum pump which solved the problem.Purchased my 62 lmpala less than a year and it already came with disc brakes front and rear , I noticed that I have to apply firm pressure in order for car to stop, I replaced all the brake pads and bled the brakes but still the same . My pedal does not go all the way down . Goes about half way my only problem is the brakes don’t grab and I have to apply the brakes kind of hard , I don’t know what brand kit this is, any input? View attachment 32041
Good question, I’m buying a vacuum pump and will check, do you have a part number on the vacuum pump you Installed?How much manifold vacuum do you have. My aftermarket disc brakes need a minimum of 14 -15 in. I only make 12-13 in. Which gave me a hard pedal needing a lot of force. I ended up installing a vacuum pump which solved the problem.
