Hubbard's Impala has some good kits available.
👌Hubbard's Impala has some good kits available.
I used one of the smaller diameter conversion kits... they do have the power to lock up the front brakes and I haven't had any issues with heat soak but I drive the car very cautiously and leave a TON of room for braking typically.The problem with aftermarket conversion kits is they use smaller 11" rotors, which were designed for the Chevelle. Full size Chevrolets used larger 11¾" rotors. This does not seem like much, but it is a big difference.
Here is my suggestion: Swap in disc brakes from a 1969-70 Chevrolet Impala/Caprice. These use the 11¾" rotors and single-piston floating calipers. I just picked up a set from a local self-serve wrecking yard. They do still show up from time-to-time, so be patient...
How was it?I literally got them 2 days ago on Wednesday, lol...
