1 - 1 of 1 Posts
Banned
Q: I found an icon written on elm327 TEST, when I press this button, it says
(This soft wear not installed on this version). I want to know is the TEST icon
means that it will give me reports about the defects of the car or not. If it gives
report I believe that this will be easily for ordinary person.
Please send to me a demo for the TEST soft wear to revise.
Also there is icon named Freeze frame, what does it mean?
A:yeah, elm327 “TEST” icon is car test function, but why it says “Display
mode 5,6,&7 test results(not implemented in this version”, because you did not set elm 327 COM Port.
Go to EXIT from elm327 test screen before change the COM Port number, then
how to set the COM port, under the elm327 software, there is a file folder named
“USB Driver”, open it you will find a PDF file named “ComPort.PDF”, it tells
you how to Changing the COM Port Number, the following parts is a short instruction :
With the release of V1.02.07, FTDI has introduced a properties sheet which allows the
user to change the
COM port number of a USB serial port.
From DeviceManager, select "View devices by type", then "Ports (COM & LPT)".
Select the USB serial port and click Properties. Select the "Port
More details see them here: ELM 327 Technical Service from uobd2.com.
uobd2 customer service will offer you elm327 video teaching you how to use elm327.
1 - 1 of 1 Posts
