1 - 20 of 25 Posts
Would love to have a clean shop like that. Would also like to be working from home, I might be able to make some big progress then. March 22nd my Pro Street project body goes under the blaster to see what all I have left to work with.
Reactions: BA.
I clean the shop quite a bit...
Just finished the garage this year and trying to enjoy the build process. It's a lot more fun putting together parts that are no longer greasy.
Great setup. You seem to have a clean and relatively safe, well thought out work space. However, be careful with the cinder blocks under the body. Take extra care or precautions if you will be under that at any time. I have seen/experienced in the past where cinder blocks have given way unexpectedly with no warning.
It looks like you have built wooden jigs for your frame and other projects. I'd feel better if you had a wooden jig for the body. Plus you have put casters on it and move the body around where the cinder blocks are fixed/stationary.
Otherwise, very impressive work!
I built a rotisserie for the body for about $300 doing the welding my self. Used 2 engine stands for the rotators. Next is a frame jig, but my jig will have to be built to some pretty exacting standards as it will be the jig used to replace 2/3 rds of the frame with a 26" back half and narrowed rear end. Has to have good reference points for rear axle location and geometry with what will be left of the original frame and suspension. I've been told the jig can take longer than the actual frame modifications. This should allow me to get 18.5 inch or 21.5 inch Hoosier radials in back for the street and 16-18 inch slicks for the track.
Reactions: BA.
Discussion Starter #10
The cinder blocks are oriented in the direction they were designed for so should not be and issue just sitting there. I won't be working with it at all while it's up there, it's just out of the way while I finish the frame. I'll set it back down and let a much more experienced guy do the paint and body.
John, how did you end up refinishing the frame? Dipped or media blasted? Something else?
For the above two posts - were they able to get inside the boxed frames at all and treat those surfaces?
Discussion Starter #16
Not really for sandblasting. The only way I've seen is an acid dip and that's not something I wanted to get into. For frames that are generally solid, the convention seems to be that no one does anything about stripping internally and they just use their preferred sealer like a paint or cavity wax.
Rust is one of the best anti oxidation coatings around, as long as it isn't flaking or disturbed. I'm probably going to blast my Convertible frame and then apply POR-15 as much as possible on the inside of the frame. On my Pro street I'm not sure what I will do yet. I'm only keeping the front 1/3rd of the original frame, but if I blast it the frame would have to be blasted prior to modifications since during modifications the frame will be welded to the cars rocker panels. Granted at a later date I might chop the remaining frame out and go tubular to cut down on front weight and try to go faster.
Discussion Starter #18
Learning the reason for "mock up" parts.
New control arms showed up with this going on:
Everywhere is out of stock on them so no idea when I'll be able to get a replacement. These are American-made and I'm trying to keep the car in as many US parts as possible but to move forward I'm going to have to buy a set of the Chinese knock-offs to mock up the assembly. I don't relish the idea of doing it twice but it will be interesting to put up a side by side comparison with new parts from Global West and wherever the copies are coming from.
I looked at the Ridetech option but I'm a little wary of how much travel I'll be getting out of their control arms for a street car, plus I've already got expensive adjustable shocks that I don't want to replace with expensive struts.
John, check out UMI Performance - they are based in PA (heart of steel country) and all parts are made in the USA. They are also cheaper than Global West. I'm not 100% sure what they have for a '69, but all their stuff I've put on my '68 has been great.
Looks like some one dropped that one off the Empire State building. That is an awful big ding for just falling off the work bench, unless that metal is very soft (in need of retempering).
1 - 20 of 25 Posts
