Hi All,
My car is a 62 Bel Air Wagon, SBC327, 700r4, 6-pass.
I recently added a GlobalWest tube sway bar (the big fat one), and put in new CPP upper and lower tubular A-arms. I also have the CPP 500 steering box and their centerlink setup.
It all seems to handle pretty well. I think I need to realign the car and I may also need a new tire as one of them is worn a bit uneven.
My question however, is that when the car is at rest, the sway bar actually touches the tie-rod adjusters on the centerlink. Is that right? Doesn't seem right.
Thanks -
Jon
Interesting dilemma, and clearly not right but I'd guess that GW hollow-center swaybar is notably larger in diameter than stock. What would stock be, like 5/8"? The GW is probably a good 1 1/8" - 1 1/4" right?
Unfortunately I have a 66 and I think a different rear-steer setup, with the swaybar up front far away.
Got any pictures?
May have to space the bar off of the adjusters with steel shims as constant rubbing will destroy the softer metal.
Hi All,
Thanks -
Jon
You will need to align (NOT to the GM specs) the car because the steering box requires 3-4 degrees of + caster. I believe the CPP upper arms have something like +5 caster built in.
The GW Part # SB5864G sway bar? I choose that one because it mounted in 'front' of everything, was a simple 'U' shape w/o multiple 'bends' to weave amongst the steering/suspension parts. It interferes with NOTHING.
Regardless it should not be touching. It is installed wrong, or perhaps springs are sagging too much. Or something else is amiss.
Thanks all. Alignment is on the schedule.
I don't think shimming it will help, but maybe I need to pull it forward more?
Thanks for the tips - I'll keep at it.
