I want to install HEI in my car that currently has points distributor. It also has a factory in dash tach. Will the tach still work or do I have to install a filter?
Thanks in advance
There's a chance I am missing something but I upgraded to HEI with my aftermarket tach and have no filter and no issues.
Honestly, I'd be surprised if you needed a filter. Outside of Corvettes with plastic bodies,and rare mechanical tachs, I thought all electrical tachs were the same.
63 imp. 283. PG. 321 rear
Thanks in advance
I have an 82 Remi HEI. In my 63 impala. and the tachometer has a plug-in at the distributor cap.
The ignition control module just went bad and it’s easy to replace it. Just remember the new one that you order you should test because sometimes they’re bad. 👍🏼
