Great thx i will check it out. I dont like that front end higher look and i think what happened in my case is the previous owner removed the factory front spiral shocks and installed Bilsteins. I believe they make the front end sit a little higher up.I have the factory shock set but the car handles better with the modern shocks so they will stay therefore the rear springs would be a good option for me. I like the angle your '63 sits at.
If the shocks are the correct specs, they should not impact the 'height'. They should simply dampen the motion.
My '63 front configuration (simply info):
Front springs: Moog 658A (labeled HD, or sometimes '409'). They are stiffer than the other OEM spring options.
Front shocks: KYB kg4550. Stiffer than OEM, but no impact on 'height'. Many options are available to accomplish this goal.
Sway bar (front): global west SB5864G. After market option that significantly reduces roll and does not interfere with other components. I personally REALLY liked the 'drive'; especially cornering. Again, lots of options.
The front 'sat' at 26 1/2" from center of headlight to ground. Why? Because the 15" wheel/tire added a 1/2" to the radius of the 'circle' centered by the axle (compared with a 14"). I did not notice the 1/2".
I arrived at the above incrementally. Springs HAD to be replaced (worn out/sagging), so shocks done at the same time. That really helped the 'float' (and raised the rear as I had planned). Added the front sway bar to reduce roll. Considered a rear sway bar but 'passed' on it because I was 'happy' w/o it.
Again, just trying to be helpful.
