Greetings, I have a 1967 Bel Air and I’m changing a powerglide to a muncie and am trying to figure out if there is a neutral safety switch on a 4spd, bench seat car. My Chevelle experience had it on the clutch pedal. I can’t find any reference to it on the Bel Air manual trans. I do see where there is a trans mounted backup light switch, but nothing to prevent starting the car in gear. Thanks for the input.
Like you said. back up light was on the Muncie shifter handle (Hurst sells a micro switch and a bracket for your Competition Plus shifter). If you hit the switch with the car in gear it would jump forward, no factory neutral safety switch on a manual that I can remember. I do remember using this "feature" to move customer cars out from blocking my garage doorways when they couldn't start a number of times.
You could use a brake light switch and bracket to fabricate a neutral safety switch for your clutch pedal if you wanted one. I never owned a Chevelle; but I had over fifty Camaros and Novas that didn't have one either; I just remembered to push in the clutch before starting.
I'm with Dave. I drove many manuals (mostly full size Chevys and GTO's) in the 60's and I never came across any kind of safety switch in the starting circuit. If there was such a switch on the clutch, you couldn't 'push start' the car. You wouldn't have spark when you let the clutch out to have the tranny/clutch turn the engine over.
Discussion Starter #4
Thanks for the replies. I figured as much. I think the Chevelle clutch ones started in 1969. My Chevelles were all 70-72, and they all had them.
Discussion Starter #5
Wires
So if manual trans cars didn’t have a neutral safety switch, was the dash harness different? The two beefy purple/white wires that plugged into the the switch didn’t exist? As an alternative to a jumper wire, can I just eliminate the connector and solder the two together, for a more positive connection? Thanks
I do KNOW the answer to your question. I don't do automatics in vintage cars. But, if the ignition circuit requires to be 'run' thru the auto trans to be 'closed' (the circuit is 'closed' in Park or Neutral ONLY, 'open' in any other position), then it seems to me that the ignition circuits for the auto and the manual HAVE to be somewhat different. Perhaps the harnesses too.
A 'fix' that 'closes' the circuit w/o an 'opening' via the transmission should 'work'. I've never done it.
This is simply what makes sense to me. I may be full of donkey doo :wink2:
