1961 Impala 2 Door Sedan
Hello all!
My name is Mike and I've been the caretaker for a 1961 Impala 2 door sedan for 6 or 7 years now. My grandfather bought it from the original owner (sold in SC), sold it to a buddy who was begging him for the car, bought it back right before I got it with the intention the my dad would buy it from him. Turned out I loved driving it so I bought it from my dad shortly after we got it home.
Known:
  1. It was originally a 283, column shift automatic.
  2. 2 door sedans are very rare and this is a one year body style for the Impala trim.
  3. The original color was Corona Cream.
  4. The previous owner put a 267 🤮 in it with a 3 speed column shift manual.
Work I have done so far:
  1. Rebuild the rear drums
  2. Front disc conversion
  3. All new stainless steel hard lines and flex lines for the brakes
  4. Booster with dual reservoir master cylinder and rear pressure adjuster.
  5. Painted the engine bay using POR 15
  6. All new parking brake cables and lubricated the parking brake assembly
  7. Replaced the steering column upper bearing and everything related to the turn signal assembly
  8. Replaced the 267 with an older built mild 283.
  9. Replaced the stock wheels with hubcaps with aftermarket chrome rallies to clear the calipers.
  10. Replaced the fuel filler neck along with any rubber parts.
What I want to do:
  1. Replace all suspension and body rubber parts. I have some already.
  2. Replace/rebuild the steering system. It all works and isn't overly sloppy but just tighten everything up.
  3. A/C
  4. LED lighting
  5. Install a 348. I already have the engine but have to tear it down and rebuild it.
  6. Install a 4 speed Super T10 floor shift.
  7. Have the few minor rust spots fixed and the paint blended in. I actually like the color it is now, it's unique at car shows.
  8. Recondition/replace all of the chromed items.
  9. Air suspension to maintain the great ride and stock ride height and let it sit lower while parked.
I'm sure I'm missing some information. Below are the couple pics I have handy and a link to a youtube video of the car. I'm a father of 3 young children so the "want to do" items are mostly pretty far down the road, the priorities right now are keeping it safe and drivable, no major projects that will keep it off the road for years.
29933
29932
Way cool car. I'm fairly familiar with them --> my nephew has a 1961 Bel Air 2 door sedan that I helped resto-mod. And yes, this body style in Impala trim is unusual. I have seen a few of them.
Reactions: cintocrunch
Last year for the Impala in a 2-Dr Sedan.
Actually the only year in a 2-Dr Sedan !!
Interesting cars indeed.
To add a little extra, they made an Impala 2-Dr Sedan as mentioned and you could also get a Bel-Air in a 2-Dr Hardtop in '61.
This is simply a 'process' suggestion:
Prioritize your 'to do' list. Not 1,2,3,...; but in categories. Something like:
Cat 1: can't drive without fixing
Cat 2: drivable but very irratating; reduced confidence in drivability
Cat 3: drivable but can wait
Cat 4: routine maintenance
Cat 5: nice to have
Cat 6: thinking about
Or those of your own choosing/definition. Keep the list a 'living' document that you add/subtract items as required.
Spend money/time on the higher priority items first. BUT, be economical, if your are 'fixing' a Cat 1 item in the suspension, and there is a lower priority suspension item;'fix' them at the same time (while the suspension is apart).
Mostly just common sense.
Another opinion:
Looks like your are not restoring for total originality. If so, nix the 348. A small block 350, or better yet a '383', is likely less expensive, more reliable, and a much better performer than a 348. I would avoid the risk of finding a suitable 348 block for rebuilding.
Just food for thought.
Really cool car you got there. Glad to see you're putting so much love into fixin' it up and making it a road warrior again!
Thanks!
Thanks! I won't say it's the best looking Impala but it's definitely distinctive!
That's what I have come to understand, the only year.
Neat, I did not know that about the Bel Air. Chevy was doing all sorts of body style shuffling that year!
Cat 5: nice to have
Another opinion:
Appreciate the feedback! Some of what you said I've already been implementing, others I can add to the process.
Regarding the 348, I have one already sitting in my parents' barn. I plan on stripping it down and sending it to a machine shop to see if it's worth building. I think the look of the W motors is really cool and I like that it's a period correct engine, and that when I go to a car show I'll likely be one of one or a handful of people with a W motor. I like having something different, kind of like the one year only 2 door sedan and the color, it makes the car more popular and after seeing a sea of Camaros and Mustangs people tend to take in my car a little bit longer.
But yes, if I run into any problems I'll be doing a mild 350 or 383 build, I'm looking for reliability, drivability and sound more than outright performance. I might consider an LS 5.3 or something similar as well, I've done tuning on modern vehicle and am not afraid of the wiring or tuning aspects.
Discussion Starter · #8 ·
So it's been a year since I posted an update...
Brakes - I kept having issues with the front calipers locking up after 10 or 15 minutes of driving. The disc brake kit I had put on wasn't in bad condition but had sat in the car for at least 10 years before I got it. So I got new calipers and pads... no change. Adjusted the brake pedal pushrod. No change. Was about to grab the stock parts off the shelves when I stumbled on an Olds forum that said there is an adjustable pushrod between the master cylinder and the booster, and that even though the disc brake conversion kit company says its preset it was that users problem. So I pulled the master cylinder off the booster, turned it back a full turn it completely fixed my problem. I need to adjust the pushrod out a turn or so since I have a little bit of dead travel before any bite but that's easy to manage.
Cooling system - I've also had consistent drips off of the lower radiator hose that I could tell was coming from somewhere on the water pump and had pooling on the intake manifold that I assumed was coming from the swiveling thermostat housing. So I replace the water pump and the thermostat housing, put thread sealant on the bolts and put water pump RTV on both for extra measure. My leaks at the lower radiator hose disappear but I was still getting pooling on the IM, BUT the thermostat housing boss on the IM didn't feel wet like coolant had been on it. I decided to check on the IM bolts and pull the first 2 or 3 on each side to put thread sealant on them in case they were in wet passages. Turns out almost all of my IM bolts were 1/2 turn or more loose, so I took them out one at a time, put on thread sealant and and retorqued them all. Also replaced the crappy o-ringed plastic drain plug for the radiator with a factory style petcock.
No more leaks!
Warning, for those of you with spotless and perfect engine bays, don't look below. For those of you who don't mind seeing a work in progress that is old, tired and leaky, look below. I don't usually open my hood at shows but it's on the list to try and clean the area up after I get through a few other projects.
Audio equipment Gas Kitchen appliance Electronic device Machine
Automotive tire Gas Tread Machine Engineering
Motor vehicle Automotive fuel system Automotive design Automotive exterior Vehicle
Motor vehicle Hood Vehicle Automotive tire Automotive design
