1 - 9 of 9 Posts
I'm going to put a new Lares 974 steering box in my 67 Impala. What is the best power steering fluid to use. I am going to flush the system. The power steering pump is fairly new.
I believe DOT5 is synthetic and probably "the best" but if you aren't auto-crossing or in super extreme temperatures, I would probably just use standard DOT3 fluid. Either can be had from any auto parts store - common stuff.
To show my 'un-bias', I have an aftermarket steering box too, and just bought regular ol' parts-store-brand DOT3. Just be aware that you can't keep that stuff on your shelf at home for a long time, it can (over time) absorb water from humid air.
Thanks for the info. I do have an old bottle of it. Now I won't use it. I will buy all new. Do you know how much it will take to flush the old and have enough to fill with all new fluid?
I think he is as well. Power steering fluid is just hydraulic fluid. Since mine leaked from a bad hose I bough it by the gallon from my John Deere dealer. It is all ten weight mineral oil. Even the tranny uses it, but ATF has a red dye in it to warn you that you not only have a leak, but what is leaking, compared to all of the other oil leaks old Chevys have.
With the DOT 5 or DOT 5, I think you are actually refering to Brake fluid.
OH ****E! You're both right!! I dunno where my head was at!!! I gotta stop reading the forum while drinking straight Bulleit bourbon!
Sorry! Man, I deserve negative points for that one. :surprise:
Do not put brake fluid in your power steering! It will destroy your pump, and your brand new steering gear. Either use transmission fluid or mineral oil like stated above.
1 - 9 of 9 Posts
