1 - 20 of 45 Posts
1960 Impala 4 dr sport sedan
Good afternoon all. I have a 1960 Impala, has been running great. Now all of the sudden, i have absolutely no electricity. Battery is good. Just replaced a bad positive cable and also the negative one. Still nothing, no lights, no horn,no interior dome lights. Please help.
What is the other end of the Negative Cable attached to?
When you attached the Negative Cable to the block, did you wire brush all contacts?
As well as tighten the bolt pretty tight?
Check each cable for continuity. Also check if your battery has 12+volts.
First thing I would do is test for power from the battery at the ignition switch & if there's power then test for power out at the ignition switch.
Discussion Starter · #12 ·
Might check the connector of the wire harness at the firewall (I think they had that back in 60). Give it a good wiggle or take it off and look for burnt contacts on the larger wires.
No burnt up connections. Cleaned up connections as best as I could
Most likly firewall connectors. They corode over time. Remove the firewall connectors at the fuse box and check for corosion. Clean each indivdual pin and re connect the connectors. Also check the battery connection at the voltage regulator.
Discussion Starter · #15 ·
I quickly wire brushed them. I'll do it again, more thoroughly
1961 Impala 2 Door Sedan
I had this issue at one point. It was the plastic becoming "weak" over time and letting the plug loosen just enough to not make good connection.
I've had some trouble with the bulkhead connector myself. I'm not sure how much experience you have with this stuff but here is a picture of roughly what it looks like on a different old Chevy.
It just snaps in place like most electrical connections. It may have tar/rubber sealer **** around it to keep rain/water out of the connections. It's just to the right of the steering column on the firewall in the engine bay.
Can you use a voltmeter/multi-meter to check for 12v at the voltage regulator? Do you have a 2nd small wire connecting to the Battery positive post?
Motor vehicle Electrical wiring Gas Cable Auto part
Motor vehicle Bumper Circuit component Automotive tire Automotive exterior
Discussion Starter · #18 ·
Discussion Starter · #19 ·
I don't have a 2nd wire from the positive post. My firewall connection is a single, not a double. I've been working on cleaning the pins on both sides of the connection.
Double check your Wire Connections at the Starter Solenoid as well.
1 - 20 of 45 Posts
