Rust - Is it worth it to try and fix?
1 reading
1.2K views 6 replies 5 participants last post by  BA.
#1 ·
Looking at a ‘67 in FL. It’s got its fair share of rust in the trunk and on the dash. Is it worth it to try and fix/repair/replace or should I just rule it out completely?
#4 ·
The trunk floor is pretty typical. Not too tough for someone who knows how to weld sheet metal. The dash/cowl is likely going to be more of a challenge, and I'd venture to guess there's more rust than what you can see.
Unless this '67 is especially desirable to you for some reason I would likely keep looking, and certainly if you will need to have someone else do the work.
#6 ·
My 65s trunk looks about as bad as yours. I'm just going to replace it with the repro trunk pan, as someone else mentioned. They aren't terrible expensive. I found the one for my 65 on classic industries for $900, or $1500 if you want it to come with weld thru primer coated. I was expecting much higher prices. edit: the dash may be trickier, if the 67 is like the 65, with the dash being a part of the frame of the car.
