Hi All
Starter keeps cranking when kry is released.
1966 Belair. installed a new M H Electric wire harnesses. Made for an internal voltage regulator. And HEI distributor. All new wiring under the hood and under the dash. ignition switch is original. We tested it and is good. But not sure about the tumblers.
We thought maybe the starter needed to be shimmed. But it seems to turn over easily. The starter is rebuilt be a shop and not a re man.
we checked the battery cables and all the grounds.
Also when I got the car many years ago there was no horn relay. I purchase one recently. The big red wire from the harness. Does it matter what terminal it goes on the relay.
I believe I covered everything.
what can cause the starter to do this.
thanks.
thanks.
