Yes! Good point. I do the same thing as you. I make sure I have a way to track these things. I have a tendency to mark items or lay them in the way I remove them. Sometimes I take pictures. With the control arms, I always have a mnemonic in my head I use. I always think "bumps to the front". The upper control arms have a raised bump on one side and a recess in the other. The recess area points to the back. The other raised part, the "bump" faces front. That is how I keep it sorted in my head.I know it’s probably not the case, but are you sure you didn’t mix up the upper control arms when you installed them after the re-bush?
I had both of mine laying on the bench at the same time. I thought to myself, I better mark these things or a week from now sure enough I’ll be scratching my head which side was which. Just a thought
Good thinking though. Ironically, I wonder what it would be like if I swapped them.....
