Problem: after running or driving car for 45 mins to an hour, if I shut it off for more than half a minute, it won’t start again. I get red lights only where the hot/cold temp lights are. Don’t know if these lights are oil temp, or engine temp. Have to wait at least 2 hours, or jump to start again.
fan is on blowing hot air.
Lower rad hose is hot, but now I’m starting to think I have installed the thermostat upside down,(unlikely) or I’m having a temp issue in coil or an Issue with the temp sensor on block?
some other things I may note as background information: ive replaced battery and cables, and starter. Had to use a butt connector on S cable for starter and multiple washers to make a solid connection. Voltage is better after doing this.
the “temp sensor” I’m referring to is the two prong connector attached to the top of the block (for cluster).?
