Hello again everyone! The last time I asked for advice about my 63's steering sway I got A TON of great info and it worked wonders on my "new" car.
The only bad thing is... when you buybone of these classics from someone who didn't take care of it like you would, shortcuts get taken.
Okay so, to the heart of the issue, I would like to know of any suggestions for aftermarket wiring harnesses. My mechanic said it's basically everything under the dash and forward. The harness in there actually had an original ignition key taped between to wires acting as a jumper. My guess is they cut the wires too short? Who knows... but this is what happened.
I was taking it to get new tires and the "BRIGHTS" indicator light popped on all by itself. Sure enough I pull up to the Goodyear store and the reflection in the window showed all 4 lights on, even with the headlight switch in the off position. My buddy, who manages the shop, actually wiggled the harness and the lights shut off. Then I shut the driver door. They all popped right back on.
So if anyone can suggest a company that has the harness it would be a huge help.
Thanks again in advance!
Erik
Erik
