Any good ideas regarding this?
I own a 1965 SS fitted with UniSteer rack and pinion kit 8010280-01. Bought the car with the kit already installed on the car. The car is also fitted with a Wilwood disc brake conversion kit and 2" drop spindles.
Turns out the former owner was plagued with bump steer on this car, while the UniSteer kit was mounted directly onto the 2" drop spindles.
So he modified the tie rod ends - basically lengthening them and increasing the angle on the steering rods, in order to eliminate bump steer. The problem with this solution is that it brings the tie rod ends veeery close to the road, and inevitably one of them slammed into the asphalt when I rode over some hard to see bumps. The rod end bolt snapped, and the right wheel was suddenly free to turn whichever direction it wanted. Not an ideal situation.
So, what should I do here? Is there a bump steer correction kit I can use? That probably won't solve the issue with the tie rod ends being too close to the road.
Should I go back to stock height spindles? Will the original spindles for the original drum brakes fit the Wilwood disc brake conversion kit?
Any suggestion is very much appreciated.
Thank you.
Thank you.
